• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    casey.heater
    Symbol Library Pointer After 2012 to 2013 Update
    1422 Views, 6 Replies
    04-10-2012 05:14 PM
    I have installed the latest AutoCAD Electrical 2013 after using 2012.  I have made a few symbols and I find the default file path attempts to place any new symbols in the 2012 directory.  Where can I change the default library location for new symbols?
    Casey
    Please use plain text.
    Employee
    RobinShou-Autodesk
    Re: Symbol Library Pointer After 2012 to 2013 Update
    04-10-2012 08:45 PM in reply to: casey.heater
    Try to change the symbol lib path for your activated project in project manager should help. As the symbol build default file path is the same as the symbol lib path for your activated project in project manager
    Robin Shou
    Quality Assurance
    AutoCAD Electrical
    Autodesk, Inc.
    Active Member
    casey.heater
    04-16-2012 07:30 AM in reply to: RobinShou-Autodesk
    Thank you Robin.  That resolved the problem.  Could you please communicate this issue to the developers?
    I am guessing I may have used a prior project as a template and version 13 did not recognize the prior paths were based upon an older version.  It would be nice to have a pop-up noting the template is based upon an older version.
    Thanks again,
    Casey Heater
    Employee
    RobinShou-Autodesk
    04-16-2012 07:38 AM in reply to: casey.heater
    Sure, we will consider the issue in future.
    Robin Shou
    Quality Assurance
    AutoCAD Electrical
    Autodesk, Inc.
    New Member
    06-28-2012 06:43 AM in reply to: casey.heater
    How do you install additional PLC'S to ACAD Electrical 2013 (other brands or legacy)
    *Expert Elite*
    06-28-2012 07:46 AM in reply to: gatwood
    Use the PLC Editor, just like in all the other versions.
    You should start a new thread for this question instead of highjacking a completely unrelated thread.
    Bob Hanrahan
    Ace User since 1998
    New Member
    Symbol Library
    01-08-2013 02:59 PM in reply to: casey.heater
    where can I find the symbol library for surveying in 2013
