AutoCAD Electrical
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Andrew Fenton
Symbol Alignment with Wire
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
66 Views, 3 Replies
02-05-2004 12:55 PM
My use of Autocad Electrical began earlier this week.
I have encountered a problem where my custom symbols made in separate .dwg
files do not lay exactly on the wire when I insert them using Insert
Component. Using my mouse, I locate the block image so that the 2 (1 left
and 1 right) wire terminals in my symbol lie precisely on the wire. When I
click the mouse button, however, the symbol block I am inserting shifts up a
pixel or two, depending how closely I am zoomed. This occurs whether or not
SNAP is activated. Apparently, the insertion is otherwise working properly
as it breaks the wire.
I believe I am using the necessary attributes. Furthermore, this problem
occurs only with some of my custom symbols. All of my symbols use an
insertion point of x = 0, y = 0, and z = 0, which is at the precise center
of my wire terminals.
Any advice with this problem would be greatly appreciated. One of my
problem symbols is attached so it may be inspected and tested.
Andrew
P.S. I read Lint's response to the 11/25/2003 posting entitled "Create new
item." In it, he advised that the WD_M block not be inserted on our
symbols. As I understand it, this WD_M block is invisible. How do I
determine if it is on my symbol, and if so, how do I get rid of it?
Attachment not added (too large): "HPB1_PRNTmPushBtnNC.dwg"
Andrew
Re: Symbol Alignment with Wire
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-06-2004 06:18 AM in reply to:
*Andrew Fenton
Several years ago, when the product was known as Cimlogic Toolbox WD, there was something about having a symbol's insert point NOT being on a wirecut point. It sounds like you may have your insert point near a wirecut. All of our custom symgols (we have hundreds) have been build with the insert point near the center of the geometry, for instance a pushbutton's insert point is centered between the left and right wirecut points. I don't know if all this is still true, but none of our symbols cause problems. Hope this helps.
Martin
Martin
*Nate Holt \(Autodesk\)
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-06-2004 07:08 AM in reply to:
*Andrew Fenton
Andrew,
AcadE automatically tries to align the inserted symbol in line with the
insertion points of the wire connection attributes X4TERM01 and X1TERM01
(for a 2-wire device) so that tese align with the underlying wire. If the XY
coordinates of these attributes are not sitting on Y=0.0, then you'll
probably see a problem like you describe. Check it out. Make sure these
invisible attributes are "Left" justified and at the exact point where the
wire is to touch the device.
Nate.
"Andrew Fenton" wrote in message
news:4022ad1d_2@newsprd01...
> Hi,
I
a
not
properly
> Thanks,
> Andrew
new
*Andrew Fenton
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-06-2004 08:21 AM in reply to:
*Andrew Fenton
Martin, Nate,
Thanks to both of you for your suggestions. Apparently, the problem was my
justification of the X?TERMn attributes. As soon as I set them to Left
justification, SHAZAAM!, their terminals snapped precisely to the wire.
When I was originally setting up my custom symbols, I thought they would
look better if the X?TERMn attributes were as symetrically justified as
possible. Foolish mortal! I should have recognized that even when the
anchor point for Middle Left or Middle Right appeared, the Left justify
anchor remains in its position with respect to the attribute tag. Thus,
when I was placing my components, the program was aligning the new component
to the Left justify anchors, which, given my Middle Right or Left
alignments, made the symbol appear above the wire to which it was connected.
Superb! Thanks again.
Andrew Fenton
