AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Swap a block project wide
- Highlight
- Email to a Friend
- Report Inappropriate Content
Using AE2012. I'm having an issue with project wide updates. I'm using swap a block as an example. The only project wide feature that is working currently is the title block update.
What is happening is that when I select, for example, a block to swap and then select project wide and the specific drawings to proces, AE does the first drawing only, then stops.
Has anyone else experienced this?
Re: Swap a block project wide
- Highlight
- Email to a Friend
Hello
You question caught my interest as I have had considerable issues learning this program.
The command does work for me as I had some time and did a test. I have had problems with this in the past and not bothered with this feature.
I ticked "do all" and it is very slow. I am on ACE2012 64bit i7 processot 8gb memory.
see added screen shot as this is what I use.
My drawing set is not large and I would normally do it sheet by sheet due to the slow implimentation of the update command.
I did not test if it would swap with a different family.
cheers jq
- Highlight
- Email to a Friend
That is strange.
I just ran a small test and inserted a single soleniod on 3 seperate drawings and then used swap block and selected a different solenoid from the menu and had no trouble updating the 3 drawings.
Are you pulling the drawings from across a network? That will slow things down during project wide functions. It usually is still managable though.
Ace User since 1998
- Highlight
- Email to a Friend
Thanks for the replies guys.
It turns out that our CAD administrator had recently added some start-up routines that were interfering with the software. As soon as he removed them, I got full functionality back. I guess that's what you get for having a piper as administrator! :-)
So problem solved.
