• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Swap Block Function - Swapping template title block/borders
    158 Views, 4 Replies
    01-29-2013 08:06 AM
    I have used this function to update title blocks on projects and it has worked for me with no problems occurings. However that is when I do not need to update the border. I now need to update the title block and border template. This function does not work for me on this occasion. I think it's because the border is not a block. Can someone please advise how this can be done.
    Thanks in advance.
    Please use plain text.
    Valued Contributor
    Re: Swap Block Function - Swapping template title block/borders
    01-29-2013 06:50 PM in reply to: STEVENAR
    I believe you need to convert the border into a block first. Then you can update both the title block and border block together. But you need to modify the project.wdt file as well to add in the new border blk and its attributes. For Example: BLOCK=TITLEBLOCK,TITLEBORDER TITLE1=LINE1 TITLEBORDER1=LINE1 ........ I am also trying to find the best way to create my titleblock as well. Hopes this helps.
    Valued Contributor
    Nata_ly
    01-30-2013 12:08 AM in reply to: STEVENAR
    As you can see in Template folder there are many templates of different formats. So what I can advise (and what I activly use) it's make all necessary templates like ACE do. Border+title, all in one block. It could take some time but it's really useful!
    Valued Contributor
    01-30-2013 01:19 AM in reply to: lionSG
    Thanks for your reply.
    I have done as you said and it seems to update the template border & title block. However when you try to run an update on the title blocks attributes, it says wdt.file not found. However when I explode the drawing, undo and then run the titleblock update, the title block attributes are updated. Strange!!
    Can you advise why this is happening?
    adrien.levasseur
    01-30-2013 04:32 AM in reply to: STEVENAR
    By my side, i use a block ACADE_TITLE with the invisible attribute WD_TB.
    The WD_TB make the link with your attribute as the project.wdt does.
    Why not using this method ?
    I do remember you need to write a line in your wdt file in order to make it search inside a block....
    For me, should be :
    BLOCK = ACADE_TITLE
    But might be the block needs to be purged...
