• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    CAD-ICE
    Accepted Solution
    Source destinaton arrows...
    335 Views, 7 Replies
    09-14-2012 06:09 AM
    Hi there,
    I have an issue when inserting source/destination arrows.
    For some reason my ACADE (2012) inserts previously defined symbols instead of the standard symbols that are delivered in the IEC2 library? Even if I use the symbol update block tool I still get the wrong block on my drawing (see attached picture). There must be some sort of setting where it´s defined what block the software uses...but I cant seem to find it. In my drawing properties I have set the arrow style to 1 for your information.
    Thanks and regards, Gary
    Please use plain text.
    *Expert Elite*
    Re: Source destinaton arrows...
    09-14-2012 07:06 AM in reply to: CAD-ICE
    Update block will only work when the block name is exactly the same.  Delete all arrows and purge the drawing of all unused blocks.  This should allow fresh symbols from the assigned library to be inserted.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    CAD-ICE
    09-14-2012 07:30 AM in reply to: dougmcalexander
    Hi Dough,
    I have tried what you said that is deleted all arrows and purged the drawing but still with the same result!
    I have double checked the library path and the path´s are in order. So that´s why I´m confused...?
    Attached is one of dwg´s from the project I´m working on.
    Thank´s again for looking into this.
    Regards, Gary
    *Expert Elite*
    09-14-2012 07:51 AM in reply to: CAD-ICE
    I ran the update block utility and it replaced your arrows with the ones from my IEC library.  Someone must have changed the symbols in your library folder. Drawing attached.
    Doug McAlexander
    CAD-ICE
    09-14-2012 07:58 AM in reply to: dougmcalexander
    That is really somewhat unbelievable? I have tried the same thing even on several IEC2 libraries from different versions that I´m certain of being original symbols. I alway´s get the same result, the refererence is ok, but no arrows?
    Thank´s again and regards, Gary
    *Expert Elite*
    09-14-2012 08:01 AM in reply to: CAD-ICE
    We are dealing with computers here.  It's amazing that the richest man in the world got there with an imperfect product.
    Doug McAlexander
    CAD-ICE
    09-14-2012 08:44 AM in reply to: dougmcalexander
    Hi again Dough!
    for some reason when I was updating the symbol the old symbol pointed to a library path from another project?
    I didn´t notice it since the path was wery similar to the default path in this project.
    Sorry for dragging you into this...and thank´s again for helping me out.
    Regards, Gary
    *Expert Elite*
    09-14-2012 08:46 AM in reply to: CAD-ICE
    No problem Gary.  I'm glad to help.
    Doug McAlexander
