• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    Source / destination arrow - attribute WIRECOLOR
    116 Views, 3 Replies
    09-20-2012 02:03 AM
    The attribute WIRECOLOR is not available with the command Edit Component.
    How can we use it with AcadE ? and not just attedit.
    Please use plain text.
    *Expert Elite*
    Re: Source / destination arrow - attribute WIRECOLOR
    09-20-2012 06:02 AM in reply to: Wheelie22
    The color of the wire comes from the layer it is on, not the components. If you want to change the color, use the "Create/Edit Wire Type" command to create the layer and "Change/Convert Wire Type" command to change it.
    Bob Hanrahan
    Ace User since 1998
    09-20-2012 06:35 AM in reply to: Wheelie22
    No..
    If you double click on a arrow you get all the attributes in the Enhaned Attribute Editor, and there is a WIRECOLOR attribute there !
    *Expert Elite*
    09-20-2012 07:32 AM in reply to: Wheelie22
    I get what you are saying now. Funny thing; I checkedalf a dozen source symbols on my computer (Runnning ACE 2013) and none of them have the WIRECOLOR attribute in them...
    Not sure what to tell you. Are you using stock symbols or ones that were created by someone else? What library are you using?
    I should state that you should not be changing the attribute with the ACAD Advanced Att Editor. You should be using the ACE's Edit Component instead. If you do it the other way, the project database does not get updated.
    Bob Hanrahan
    Ace User since 1998
