• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    Signal Source and Destination Arrows With PLC Spreadsheet I/O Utility
    168 Views, 3 Replies
    10-09-2012 11:04 AM
    When using the Spreadsheet to PLC I/O Utility, I am unsuccessfully attempting to place source and destination arrows.  I am attempoting to place a source arrow and a destination arrow on the same line.  I can do this manually on the drawing with no problem.  However, when IU attempt to place a source and destination arrow on the same address line, using the spreadsheet, either the source or the destination wire connection drops out.
    What can I do to add souce and destination arrows via the PLC spreadsheet
    Please use plain text.
    *Expert Elite*
    Re: Signal Source and Destination Arrows With PLC Spreadsheet I/O Utility
    10-09-2012 12:39 PM in reply to: Outbound
    The drawing you sent out was blank.
    Could you resend it so I can take a look at it?
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    10-09-2012 01:40 PM in reply to: testsubject
    Try these in the DxBLK field:
    "HA1D3" - Destination arrow for input cards
    "HA1S1" - Source arrow for output cards
    You may also add the signal code in DxTAG fields to save time. Be sure to use a unique signal code for each arrow.
    Don't forget to try RackLayout.com when creating the Excel sheet.
    Active Contributor
    10-10-2012 06:18 AM in reply to: testsubject
    Sorry...I failed to attach the sample file properly.
    Hopefully, it willbe attached, here.
