• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    Selector Switch Contacts
    216 Views, 3 Replies
    09-07-2012 06:50 AM
    Hello All,
    I am very new to AutoCAD Electrical and I'm having trouble adding additional contacts to componts, namely selector switches.  How is that process done?  When I add a selctor switch it only adds a single contact.
    AutoCAD Electrical 2013
    Windows 7
    Thank you in advance.
    Please use plain text.
    Re: Selector Switch Contacts
    09-07-2012 09:25 AM in reply to: ccapplen
    Go back to the Selector Switch category in the menu and click on the 2nd+ contact of your choice, either NO or NC. Insert the contact next to the parent contact that you already inserted.  Click Parent/Sibling to associate this additional contact to the existing contact.  The reason Electrical works this way is so that you are not limited to a certain wire spacing.  You can insert multi-wire components across any group of wires no matter their spacing.  Hint: This same method can be used for pushbuttons, relays, and any other switching device that can have 2 or more contacts.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    Active Contributor
    huyvu90
    11-29-2012 07:45 AM in reply to: ccapplen
    If a selector switch has 4 contacts, how would you go about distinguishing between the different contacts?
    Currently I assign pin # to each contact to distinguish it from other contacts but I'm not sure if it is the right thing to do.  For example, contact #1 would have pin # 1 and 2.  Contact #2 would have pin # 3 and 4.
    11-29-2012 11:16 AM in reply to: huyvu90
    That is exactly how you would distinguish between different contacts.
    Bob Hanrahan
    Ace User since 1998
