• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    Script for turning on and off layers
    138 Views, 2 Replies
    01-18-2013 06:12 AM
    Im after a simple script that i can run to turn off my DESC layer in all my drawings or any other layer for that matter.
    Regards
    Liam,
    Regards
    Liam Barham
    Electrical design lead
    CBI Fleetwood
    Please use plain text.
    opavlica
    Re: Script for turning on and off layers
    01-18-2013 07:10 AM in reply to: liambarham
    Look under  "Projects" ->"Project (Wide)  -> Utilities -> "For each drawing" there is a check box to "Run command script file" .  <You can create a simple script to turn off layers prior to this and select it using this method..  Once you have located your .scr file, click "OK" and  you can batch process some or all dwgs in your project.
    You should also create another script file to turn layers back on if needed, for which the same process is used.
    This should put you in the right direction.
    Hope this helps!
    Omar
    Valued Contributor
    01-18-2013 09:34 AM in reply to: liambarham
    This is a sample of what you would type in notepad and save as a script e.g. FREEZE LAYER DESC.SCR
    It makes layer 0 the current layer first to prevent errors incase DESC is current layer in a drawing and can't be frozen.
    ZOOM
    E
    -LAYER
    make
    0
    FR
    DESC
                              (- this is a blank line to force an enter)
                              (- this is a blank line to force an enter and finish layer command )
