AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Script for turning on and off layers
- Highlight
- Email to a Friend
Im after a simple script that i can run to turn off my DESC layer in all my drawings or any other layer for that matter.
Regards
Liam,
Liam Barham
Electrical design lead
CBI Fleetwood
Re: Script for turning on and off layers
- Highlight
- Email to a Friend
Look under "Projects" ->"Project (Wide) -> Utilities -> "For each drawing" there is a check box to "Run command script file" . <You can create a simple script to turn off layers prior to this and select it using this method.. Once you have located your .scr file, click "OK" and you can batch process some or all dwgs in your project.
You should also create another script file to turn layers back on if needed, for which the same process is used.
This should put you in the right direction.
Hope this helps!
Omar
- Highlight
- Email to a Friend
This is a sample of what you would type in notepad and save as a script e.g. FREEZE LAYER DESC.SCR
It makes layer 0 the current layer first to prevent errors incase DESC is current layer in a drawing and can't be frozen.
ZOOM
E
-LAYER
make
0
FR
DESC
(- this is a blank line to force an enter)
(- this is a blank line to force an enter and finish layer command )
