• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    JCard
    Script breaks Project Navigation Buttons
    114 Views, 1 Replies
    10-14-2011 08:36 AM
    We have a page setup script that we were running successfully in 2011 and now seems to break in 2012.  Has the plot configuration changed?  We have also noticed that when the script bombs out, the Previous and Next Buttons for Project Navigation no longer work and require a session shutdown of ACADE 2012.  It seems as if there are a different set of plot configuration inputs between the 2011 and 2012 releases...???  We have managed to find what seems to bomb our script, but not the navagation buttons after the script breaks.
    We typically use the Project Utilities (Project Tab > Project Tools > Utilities) to apply the page setup to our project drawings for plotting.
    I have attached the old and the corrected script for review and troubleshooting. (keep in mind that these are set for our plotter PC3 and color table CTB files, so you will have to modify these to match your setup.)
    JCard
    McKee Foods Corp.
    Design Drafter
    Please use plain text.
    Distinguished Mentor
    rhesusminus
    Re: Script breaks Project Navigation Buttons
    10-14-2011 10:19 AM in reply to: JCard
    As far as I can see, the script you used in 2011 was wrong. There was a couple of y's and n's too much. but these error didn't cause any trouble, as they were in the end of the command string, and only caused a couple of "unknown command" errors, before the qsave was executed.
    The script that works with both 2011 and 2012 are:
    (command "-plot" "Yes" "Model" "Fax" "Letter" "Millimeters" "Landscape" "No" "Extents" "Fit" "0,0" "Yes" "Monochrome.ctb" "Yes" "As" "No" "Yes" "No" "qsave")
     The questions asked by the -plot command are the same for both 2011 and 2012 as you can see here:
    AutoCAD 2012:
    Command: -plot
    Detailed plot configuration? [Yes/No] <No>: Yes
    Enter a layout name or [?] <Model>: Model
    Enter an output device name or [?] <Fax>: Fax
    Enter paper size or [?] <Letter>: Letter
    Enter paper units [Inches/Millimeters] <Millimeters>: Millimeters
    Enter drawing orientation [Portrait/Landscape] <Landscape>: Landscape
    Plot upside down? [Yes/No] <No>: No
    Enter plot area [Display/Extents/Limits/View/Window] <Extents>: Extents
    Enter plot scale (Plotted Millimeters=Drawing Units) or [Fit] <Fit>: Fit
    Enter plot offset (x,y) or [Center] <0.00,0.00>: 0,0
    Plot with plot styles? [Yes/No] <Yes>: Yes
    Enter plot style table name or [?] (enter . for none) <monochrome.ctb>:
    monochrome.ctb
    Plot with lineweights? [Yes/No] <Yes>: Yes
    Enter shade plot setting [As displayed/legacy Wireframe/legacy Hidden/Visual
    styles/Rendered] <Legacy wireframe>: As
    Write the plot to a file [Yes/No] <N>: No
    Save changes to page setup [Yes/No]? <N> Yes
    Proceed with plot [Yes/No] <Y>: No
    AutoCAD 2011:
    Command: -plot
    Enter an output device name or [?] <None>: Fax
    Enter drawing orientation [Portrait/Landscape] <Portrait>: Landscape
    Enter plot area [Display/Extents/Limits/View/Window] <Display>: Extents
    Enter plot offset (x,y) or [Center] <-13.65,11.55>: 0,0
    Enter plot style table name or [?] (enter . for none) <>: Monochrome.ctb
    styles/Rendered] <As displayed>: As
     I can't however, reproduce the error you got, that the navigation stops to work when something goes wrong in your script. I've tried to create error in the script manually, but it still works as it's supposed to.
    Maybe the problems are drawing oriented, and that's why I can't reproduce the error? Could you post a drawing where the script stops?
    THL
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
