• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    David_S_Barrow
    Screened cable marker
    122 Views, 3 Replies
    10-19-2011 05:26 AM
    I added an attribute to the parent cable marker for screened cable. Not a problem I've done this on many symbols, however when I updated the symbol project wide, it moved all the parent markers out of line with the child markers? (see attached pic). As my project is very large with over a hundred cables in it, having to go through every drawing aligning them back up again is very annoying. Can anyone shed any light on why it does this? I haven't changed anything of the graphics in the symbol just added an attribute?
    Please use plain text.
    *Expert Elite*
    Re: Screened cable marker
    10-19-2011 05:34 AM in reply to: David_S_Barrow
    That is strange. I do know that if you have a grip active (i.e., snap to endpoint) it can cause problems. Was something like that active??
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    David_S_Barrow
    10-19-2011 06:03 AM in reply to: testsubject
    Nope, I checked that, I've been using AutoCAD and ACADE for many years and it didn't do this on earlier versions, or not that I was aware of. I'm using ACADE 2011, and it's up to date.
    Distinguished Mentor
    rhesusminus
    10-21-2011 06:40 AM in reply to: David_S_Barrow
    Can you take a look at where the insertion point of the original block is, using the INSERTION osnap?
    Just to check if it is AcadE's update function that creates this error, or if the error was there already?
    THL
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
