• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    lastratech
    Accepted Solution
    Schematic new file iec
    2376 Views, 3 Replies
    04-13-2012 01:57 AM
    Dear Sirs I am a new user and I have a question regarding project settings. I create a new project and in project settings I remove JIC shematic libraries and add EIC libraries but in shematic icon menu file I didnt find
    ace-eic-menu.dat   file.
    So when I start using symbols always JIC shematic simbols apply. I install all IEC (mm)  libraires  .
    (AUTOCAD ELECTRICAL 2013 )
    KIND REGARDS
    GREGOR
    Please use plain text.
    Employee
    RobinShou-Autodesk
    Re: Schematic new file iec
    04-13-2012 03:09 AM in reply to: lastratech
    When you new a project, if you want a IEC standard project, please copy the project settings from the default IECDEMO project, refer to the attached newproject.png file. By this, all the project settings will follow the IEC standard, included the symbol libs and icon menu.
    If you have already created a project in JIC standard, but want to change the symbol lib path and icon menu when insert the component, you need to change the symbol lib path first, then you need to rename the icon menu file to ACE_IEC_MENU.DAT, actully you only need to change the file name is ok, no need to know where is this file, refer to the attached ProjectProperties.png. If you still want to check the file, you can go to this folder: C:\Users\Username\AppData\Roaming\Autodesk\AutoCAD Electrical 2013\R19.0\enu\Support
    It is better you copy the project settings from the existed project when you create a new project, or you need to change lots of settings after you create the projects.
    Robin Shou
    Quality Assurance
    AutoCAD Electrical
    Autodesk, Inc.
    New Member
    lastratech
    04-13-2012 05:57 AM in reply to: RobinShou-Autodesk
    Thanks for helping me. I tried and works now. .
    Kind regards.
    Gregor
    New Member
    07-29-2012 10:08 AM in reply to: lastratech
    terima kasih ya ...sangat membantu ....:smileyhappy:
