• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Scaling ABECAD components
    94 Views, 4 Replies
    03-25-2004 05:29 AM
    I have successfully inserted panel components such as pilot lights and push buttons on my front panel layout without any problem. I actually use the enclosure drawing from Hoffman and everything is scaled properly. However when I try to insert components onto the back panel using ABECAD they are scaled much too large. How do I fix this?
    Please use plain text.
    Re: Scaling ABECAD components
    03-25-2004 07:11 AM in reply to: rta53
    You need to rescale those parts. They were probably drawn in metric. Save them to your hard drive and rescale to Standard (ft,in)
    Bob Hanrahan
    Ace User since 1998
    03-25-2004 05:27 PM in reply to: rta53
    The blocks are in metric. How do I rescale?
    03-26-2004 04:20 AM in reply to: rta53
    ok, I figured out one way to do this. I use the scale command and type a reference number and then a scale number. For example, when I bring in a 6 mm terminal block I use 6 as the reference number and then .236 as the scale number which is the decimal inch equivalent of 6 mm. Is there a better way of doing this?
    03-26-2004 06:08 AM in reply to: rta53
    That is the only way I know how to scale a part. I would suggest that you do the original .dwg so that you do not have to scale it every time you use that part. I usually use 25.4:1 for my scaling. 25.4 mm=1 inch.
    Bob Hanrahan
    Ace User since 1998
