AutoCAD Electrical
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Scaling ABECAD components
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
95 Views, 4 Replies
03-25-2004 05:29 AM
I have successfully inserted panel components such as pilot lights and push buttons on my front panel layout without any problem. I actually use the enclosure drawing from Hoffman and everything is scaled properly. However when I try to insert components onto the back panel using ABECAD they are scaled much too large. How do I fix this?
Re: Scaling ABECAD components
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-25-2004 07:11 AM in reply to:
rta53
You need to rescale those parts. They were probably drawn in metric. Save them to your hard drive and rescale to Standard (ft,in)
Bob Hanrahan
Ace User since 1998
Ace User since 1998
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-25-2004 05:27 PM in reply to:
rta53
The blocks are in metric. How do I rescale?
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-26-2004 04:20 AM in reply to:
rta53
ok, I figured out one way to do this. I use the scale command and type a reference number and then a scale number. For example, when I bring in a 6 mm terminal block I use 6 as the reference number and then .236 as the scale number which is the decimal inch equivalent of 6 mm. Is there a better way of doing this?
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-26-2004 06:08 AM in reply to:
rta53
That is the only way I know how to scale a part. I would suggest that you do the original .dwg so that you do not have to scale it every time you use that part. I usually use 25.4:1 for my scaling. 25.4 mm=1 inch.
Bob Hanrahan
Ace User since 1998
Ace User since 1998
