• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    grahamLewis2010
    Accepted Solution
    Reverse and flip components
    293 Views, 7 Replies
    08-14-2012 04:20 AM
    Hi...
    I worked out how to get my components vertical or horizontal by drawing them twice and giving them the same file name i.e VDV11_004 and HDV11_004 but can't seem to get them to flip or reverse...? can somone enlighten me??
    many thanks
    Graham
    Graham
    Please use plain text.
    *Expert Elite*
    Re: Reverse and flip components
    08-14-2012 07:47 AM in reply to: grahamLewis2010
    Can you post the dwgs so that one of us can test them and possibly see if there an issue with the file?
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    grahamLewis2010
    08-15-2012 11:45 PM in reply to: testsubject
    Hi Bob,
    I thought I had replied already but evidently not!
    Thanks for looking at this for me.
    Attached is a DWG with a component I created (a motorised Battery switch used in marine installations) I have shown it vertical and horzontal.
    Graham
    Graham
    *Expert Elite*
    08-16-2012 06:03 AM in reply to: grahamLewis2010
    I see your issue now. Flip/Reverse only works with symbols that have only two terninals. With three or more, the software cannot determine everything needed to reroute all the connected wires even if you only have two wires connected.
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    grahamLewis2010
    08-16-2012 06:24 AM in reply to: testsubject
    Thanks Bob,
    learning all the time... G
    Graham
    Active Contributor
    rwydesk500
    08-21-2012 04:48 AM in reply to: testsubject
    Does this mean that it can be flipped/reversed if no wires are connected to the "3 or more terminals" component?
    Rick Yoerger
    *Expert Elite*
    08-21-2012 06:17 AM in reply to: rwydesk500
    I  just checked. Both Vertical and horizontal symbols with both flip and reverse if no wires are connected.
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    grahamLewis2010
    08-23-2012 10:28 AM in reply to: testsubject
    Brilliant...! thanks
    Graham
    Graham
