• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Remove '-Model' from pdf file names
    214 Views, 1 Replies
    08-23-2012 04:02 AM
    Can anyone advise how to remove '-Model' from the pdf filename. I am doing batch plotting to pdf and I need to remove '-Model' from each of the filenames manually.
    Thanks.
    Please use plain text.
    Active Contributor
    stefan.stamate
    Re: Remove '-Model' from pdf file names
    08-23-2012 04:20 AM in reply to: STEVENAR
    I believe that you are using the Project->Publish option which is a bit different.
    I use the publish command from the manu (File->Publish) and plot to a pdf printer (like Bullzip PDF for instance). This merges all the drawings into one pdf. You need to create a page setup in the first drawing of the list which will use the "pdf printer" and apply this to all the drawings. This method doesn't add any "-Model" text to the filename. In fact you enter the name of the pdf. Under the Publish Options you van choose if you want a "Multi-Sheet File" or a "Single-Sheet File" controlling in this way if you want them merged or separated files.
