• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Reference contact style
    176 Views, 1 Replies
    12-21-2012 10:21 PM
    Is it possible to change the shape of contact references appear below a coil as per the attached drawing?
    Rajesh
    Please use plain text.
    Valued Contributor
    Re: Reference contact style
    01-01-2013 07:03 PM in reply to: psrajesh4u
    You can go into the drawing properties, cross-references tab.
    Under the component cross reference display, select graphical format.
    Choose the IEC graphic fonts.
    Unless you want to change the contact graphic symbol look, then maybe others can help?
