• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    Quick Access Toolbar
    353 Views, 4 Replies
    12-11-2010 05:12 AM
    My quick access toolbar disappears for no reason. I set it up, save my workspace, make sure that everything is locked. I close ACADE, open it at a later date and all my quick access icons are gone with the exception of the open and new page icons.
     Anyone else have this problem and is there anything that can be done? My thanks in advance.
    Richard
    Please use plain text.
    Employee
    Re: Quick Access Toolbar
    03-01-2011 12:25 AM in reply to: rkinsey
    Call command MENU in command line and reload acade.cuix to check if QAT comes back.
    Kevin Li
    Distinguished Mentor
    03-01-2011 03:27 PM in reply to: rkinsey
    Is that with a new dwg or is it without a dwg?
    I've noticed that if all dwgs are closed, the only menu/tool bars that are available are the ones you mentioned.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    Employee
    03-06-2011 09:53 PM in reply to: Icemanau
    That is with a dwg.
    Kevin Li
    Active Contributor
    03-07-2011 09:52 AM in reply to: rkinsey
    All, this happens with an open drawing/project. The quick access tool bar as well as the ribbon (set the size and it gradually widens). My ribbon is docked on the right side of my screen w/autohide on. Just small things that make you go hummm
