AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Put filename automatic in sheet value of drawing properties
- Highlight
- Email to a Friend
- Report Inappropriate Content
Autocad Electrical use the "Sheet value" on the drawing properties to fill in automatic the page number, next page number and use it also for component coding (%S-%N).
But, to fill in the "sheet value on the drawing properties is an manual action.
Is it possible to put automatic the filename (i.e. 100.dwg ) without extension in the "Sheet value"
Kind regards,
John
Re: Put filename automatic in sheet value of drawing properties
- Highlight
- Email to a Friend
Are you speaking of updating the title block? If so, right click on the project name in the project manager and then click on 'update title block...'; check the Sheet (%s value), and then click either 'OK Active Drawing' or 'OK Project Wide'.
- Highlight
- Email to a Friend
If I understand you correctly, you want to fill in the Sheet value automatically with the drawing value. I am not should if that is possible without writing a .lsp to do it. You can however automatically fill in the Sheet value sequentially by selecting to renumber the Sheet value during a Titleblock Update. This allows you to set the sheet value for several drawings assuming they are in order (i.e., 100, 101, 102, etc)
Ace User since 1998
- Highlight
- Email to a Friend
Hi Bob, sorry for the late reaction.
You understand my question, but your suggestion will not work for us because we haven/t sequential page numbering.
We work with standard page numbers for each part of the drawing, en have several gaps between the page numbers.
I understand that Autocad Electrical has no standard solution for filling in the sheet value automatically, so we have to write o lisp or do it manually.
Thanks for you answer.
Kind regards John
