AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Publishing default settings
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi there,
is there a way to set the default settings when publishing?
After selecting drawings to process and press press "OK" a dialog box "Autocad Electrical - Publish Setup" pops up and I can check or include what I want to plot i.e. the model and layout tab. Also I can select if I want to run publish in the background. I normally have to uncheck the model tab and check the layout tab because I alway´s plot the layout and not model tab.
Then I press "OK" and now another dialog box "Publish" pops up with the sheet´s selected etc. Here I normally select to publish to pdf and not dwf and under publish options I select multi-sheet file instead of Single-sheet file.
So my question is if I can change the default setting such that I dont have to make these settings everytime I want to publish.
Thank´s in advance.
Regards, Gary
