• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    Publisher ecsCAD using in .NET
    214 Views, 1 Replies
    08-28-2012 09:04 AM
    We developed a function to manage ecsCAD projects in a DMS/EDM system. For this we have developed an addin to do the following:
    - write a PDF using the ecscad publisher
    - zip the ecscad project
    both  document are then imported in the dms-system.
    We use ecscad 2012
    now the problem ist the publisher-function, if we use the following code to start the publisher-process:
                    string projectName = "MyProject";
                    ecsPublisherOLELib.Generation ep = new ecsPublisherOLELib.Generation();
                    ep.Init();
                    ep.Setting = "Einstellung PDF";
                    ep.Format = 0;
                    ep.Project = projectName;
                    ep.OutputFile = projectName + ".pdf";
                    ep.OutputFolder = "C:\\Temp\\";
                     //optional PDF Info
                    string[] vInfo = new string[5];
                    vInfo[0] = "Info 1";
                    vInfo[1] = "Info 2";
                    vInfo[2] = "Info 3";
                    vInfo[3] = "Info 4";
                    vInfo[4] = "Info 5";
                    ep.DocumentInfo = vInfo;
                    int r = ep.StartOutput;
    - the publisher is starting
    - I can see 1 of 4, 2 of 4 and so on
    - at the end what I get is an empty PDF (sometimes there are some fragments in there) and after this the ecscad project is corrupted, even the dwg files are empty now
    - the mdb seems to stay open (there is an ldb-file)
    Does somebody has any idea what is going wrong here, any snippes how to do it...
    Thank you for help
    Regards
    Daniel
    Please use plain text.
    Member
    WoHo
    Re: Publisher ecsCAD using in .NET
    09-06-2012 02:13 PM in reply to: innowell
    Daniel,
    the following C# code snippet works:
    [CommandMethod("ET_PDF_TEST", CommandFlags.Session)]
    //session flag necessary for all commands invoked in AutoCAD ecscad
    static public void _cmd_pdf_test()
                Autodesk.AutoCAD.Interop.AcadApplication acadApp = (Autodesk.AutoCAD.Interop.AcadApplication)System.Runtime.InteropServices.Marshal.GetActiveObject("AutoCAD.Application");
                acadApp.LoadArx("ecsPublisher.arx");
                acadApp.LoadArx("ecsPublisherOLE.arx");
                ecsPublisherOLELib.Generation ep = (ecsPublisherOLELib.Generation)acadApp.GetInterfaceObject("ecsPublisherOLE.Generation.182");  //182 correspond to ecsPublisher for AutoCAD ecscad 2012
                ep.Init();
                ep.Setting = "Einstellung PDF"; //the setting must be available in ecsPublisher
                ep.Format = 0;
                ep.Project = "M1N";
                ep.OutputFile = "M1N.pdf";
                //r == 0 ok or specific error code
    You have also to set the references to the AutoCAD COM-API and the ecsPublisherOLE.arx (COM-API).
    Regards
    Wolfgang
