• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    cbenner
    Project Wide.....
    438 Views, 5 Replies
    09-28-2012 05:22 AM
    Hi folks,
    New to Acad Electrical but not AutoCad in general.  20 plus years in CAD.  using Acad E 2013 as part of Product Design Suite.  Computer specs below.
    My problem is this:  I have been working on our first project using electrical, just a few sheets with some I/O.  So far, any of the tools that give me the option for "project wide" (wire numbering, reports, audit... whatever) lock up the system completely.  I understand it may need some time, but I left it running overnight and there was no progress (this was on wire numbering).  I can do things by sheet very quickly.... but not project wide.  I know I'm probably just missing something obvious.... can anyone offer any thoughts?
    AutoCAD 2013, IV 2013 Pro SP2 Tube and Pipe - Frame Generator, Vault Pro 2013 Win 7 x64, Dell precision PWS690, GeForce GTX580
    Thanks in advance.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Please use plain text.
    Employee
    RobinShou-Autodesk
    Re: Project Wide.....
    09-30-2012 06:10 AM in reply to: cbenner
    In ACE2013, If you have 2 monitors, the first time you run the application, the Select drawing to process dialog will appear, and now if you put it in the secondary monitor. Then you run the project wide command for the second time which need the Select drawing to Process dialog to be invoked, the application will lock up. As you can’t see the Select drawing to process dialog in both 2 monitors.
    If you are this case, please patch the ACE2013 SP1, as this issue is fixed in the SP1.  You can get the ACE2013 SP1 from here:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20545414&linkID=9240738
    Robin Shou
    Quality Assurance
    AutoCAD Electrical
    cbenner
    10-01-2012 08:42 AM in reply to: RobinShou-Autodesk
    Thanks, I've loaded the SP,... I'll post back when I have a chance to try it out.
    ChrisB
    cbenner
    10-03-2012 04:13 AM in reply to: cbenner
    This fix worked just fine, thanks again for the help!
    ChrisB
    Employee
    RobinShou-Autodesk
    10-03-2012 07:00 PM in reply to: cbenner
    Thanks for the confirm for this issue. Please let us know if you still have any issues when using the AutoCAD Electrical 2013.
    Robin Shou
    Quality Assurance
    AutoCAD Electrical
    cbenner
    Re: Project Wide..... Robin.....
    10-12-2012 04:26 AM in reply to: RobinShou-Autodesk
    Hello again,
    Having a new issue with "project wide" wire numbering.  The wire numbers are all coming in very tiny, bunched up together and in Model Space!  If I do them one page at a time, they come in just fine... and I can use that as a workaround, but what could be causing this?  Almost seems like a graphics issue?  Wierd.
    ChrisB
