• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    Project Manager box locked in leftside of screen
    276 Views, 5 Replies
    10-09-2012 05:18 PM
    I haven't encountered this before. The project manager box is locked on the left of the screen, and there is no option to move it, only to close it (see pic). I went into the CUI and tried editing it under the pallettes section, but nothing changed. any thoughts?
    Please use plain text.
    Re: Project Manager box locked in leftside of screen
    10-09-2012 05:51 PM in reply to: iomaxx
    another note, i changed workspaces to the autocad electrical default, and the box is able to be moved again. for some reason, the 'acade & 2d drafting & annotation' workspace doesn't allow the project manager box to move in any way. Is that by design, anyone know?
    10-10-2012 07:31 AM in reply to: iomaxx
    Did you try to Left Click and Drag on the Title Bar for that window? That is how I always move it.
    Bob Hanrahan
    Ace User since 1998
    10-10-2012 07:35 AM in reply to: testsubject
    yes, if i try moving it, the mouse pointer just turns to a red circle with a line through it.
    10-10-2012 07:43 AM in reply to: iomaxx
    That was all I had. Maybe someone from Autodesk can respond.
    Bob Hanrahan
    Ace User since 1998
    Distinguished Mentor
    10-10-2012 07:21 PM in reply to: testsubject
    Did you lock the position of your toolbars in the problem workspace.
    Look at the bottom left of the acade window. In the status box there should be a padlock.
    If the padlock is closed, you may have locked the positions. Right click and select the docked menu bars, then select unlocked.
    Now try and move the menu bar and see if that works. If all else fails, try unlocking ALL the items.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
