• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    CAD-ICE
    Problems when inserting multiple cable markers.....
    189 Views, 2 Replies
    10-01-2012 11:48 AM
    Hi there,
    I have a strange problem when inserting multiple cablemarkers. The problem occurs only if or when the first conductor which also holds the parent symbol is different from the first number defined in the pinlist for the cable in question.
    I have no problems inserting the cable and ACADE fetches the pinlistvalues going from 1,2,3,4...etc,
    However if i go and edit the conductors manuallly such that conductor previously defined no.1 is numered 17 and conductor previously defined no.2 is numbered 18 and following conductors get numered 1,2,3,4,5,6,7,8 (see attached image) strange things happen. For some reason this action causes the parent conductor to lose somehow connectivity with the database such that catalog information already defined in the one line schematics are not inherited.
    Any comments greatly appreciated.
    Regards, Gary
    Please use plain text.
    Distinguished Mentor
    rhesusminus
    Re: Problems when inserting multiple cable markers.....
    10-29-2012 10:56 AM in reply to: CAD-ICE
    Hi Gary.
    If you rebuild the database.. Do it "reconnect"?
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
    CAD-ICE
    10-29-2012 04:17 PM in reply to: rhesusminus
    Hello Rhesusminus,
    I´ll give it a try tomorrow to see if it reconnects after a rebuild.
    Thanks again for looking into this.
    Regards, Gary
