AutoCAD Electrical
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Problem with PDB blocks (DB)
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
82 Views, 1 Replies
01-09-2012 12:14 PM
I am currently using AE 2012 and having problem with the power distribuion block electrical symbol. I can not get AE to label wires on bothside of a pole. It only labels one wire and the other one is left unlabeled. The wire being use is marked to be labeled and there is no wire numbers on a hidde layer either.
Re: Problem with PDB blocks (DB)
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-09-2012 02:17 PM in reply to:
croland
It sounds like you have a block that is passing the wire number through.
Try inserting a wire number copy after the distribution block. If the block is passing the wire number through, your copy will reflect that.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 5 years
as Brad Coleman
as Brad Coleman
