• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    circuit1
    Problem viewing terminal symbol in "terminal strip editor" panel layout view
    94 Views, 2 Replies
    01-19-2012 02:06 AM
    I have created my own terminal block icon which i can access from the panel icon menu and i also added it in the catalogue database which is under "trms" weidmuller. I also made this block the wd_default_terminal.dwg so that when using the "terminal strip editor" and selecting the correct catalogue part number i.e my weidmuller terminal, then i should be able to view this terminal in panel layout view......
    The problem i am having is that when creating my terminal strip from my schematic by selecting the "terminal strip editor" and i select from the catalogue list my terminal it will not show the terminals in the "layout preview", it will show the tabular terminal strip (table object) and even the jumper chart if i select this in layout preview. But if i select insert it will insert my terminals.
    I noticed that when in "layout preview" in the terminal strip editor, on my command prompt it tries to load my terminal blocks but it says the following:
    Block FPT_DKT4-35 refrences itself ( where FPT_DKT4-35 is my block)
    Any ideas???
    I sometimes get a error message "Error loading Hedi Module"
    Adrian
    Valued Mentor
    rhesusminus
    Re: Problem viewing terminal symbol in "terminal strip editor" panel l
    01-19-2012 02:54 AM in reply to: circuit1
    Open  FPT_DKT4-35.DWG, and explode the block in that drawing, that is also called  FPT_DKT4-35. This is what creates the self referencing.
    Purge the unused blocks and save the file.
    Now it should work as expected.
    THL
    THL
    circuit1
    01-19-2012 03:46 AM in reply to: rhesusminus
    Thank you so much, have a nice day!
    Adrian
