• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Member
    Populate Panel from schematic list, not marking existing
    109 Views, 2 Replies
    11-21-2005 12:43 PM
    I've been using the populate panel from schematic list feature in autocad. I just ran a project resequence/retag on a set of drawings. After the run, i opened populate panel from schematic list again. I reloaded the program, and selected marked existing. However, the program will not mark some inserted footprints even though I see that they were inserted earlier from populate panel from schematic list. I've re-built the project database, reloaded populate panel, and still see the same problem. Does anyone have any suggestions?
    ~Mark
    Please use plain text.
    Re: Populate Panel from schematic list, not marking existing
    12-14-2011 03:00 PM in reply to: sparckis
    I am having the problem noted above.  I am taking the following steps:
    1. "Schematic List" in Panel.
    2. Press "Reload"
    3. Press "Mark Existing"
    4. Components which exist on the panel are not being marked as existing.
    :smileymad:
    12-14-2011 03:59 PM in reply to: sparckis
    If found the problem.  My footprint block had an "FPT" (Terminal Footprint) attribute.  The footprint was identified as a terminal rather than a component.
