• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Member
    Point to Point Wiring Diagrams
    248 Views, 2 Replies
    10-27-2003 01:53 AM
    My company prepares avionics wiring diagrams for the airlines, which are point to point, rather than "ladder" or "control" diagrams. They must conform to Air Transport Associations standards (or Boeing's). We also use those wiring diagrams for manufacturing of new harnesses. Typically they look like multiple wires between circular connectors or "black boxes". P to P is referenced in both the old WD and new ACAD Electrical but no further info or tutorials that I can see.
    The package looks really good, and I'm excited about it's possibilities. I know that I'll have to do some significant customization, and I'm OK with that. Just having a little trouble taking the first step with it. Any suggestions?
    DanG
    ASM Inc
    Please use plain text.
    *Autodesk\
    Re: Point to Point Wiring Diagrams
    10-27-2003 04:10 AM in reply to: DanG
    Point-to-point should not be a problem. You can set
    up your drawing without "ladders" - you just set up either 1) X-Y grid reference
    system, 2) X-zone referencing system, or 3) line reference number column along
    the left side of the drawing without the ladder. Then you just start popping in
    your custom, AcadE-smart avionic symbols and connectors (that you'll need
    to convert over one time) and use the "spool of wire" tool to interconnect. From
    dealings with other aviation industry folks, I suspect that you have a
    special wire numbering system that includes system and gauge and color formated
    into the tag. You can use the EDIT WNUM tool to manually assign these wire
    numbers and then, when all is in place, you should be able to extract various
    interconnection reports, BOM's and such.
    Member
    Re:
    10-27-2003 05:11 AM in reply to: DanG
    Thanks!
    DanG
    ASM
