AutoCAD Electrical
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Plot Project trouble in 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having trouble with the Plot Project command in project manager. It worked the first time I used it but hasn't since. It doesn't lock up - pressing the "esc" key will exit the command. If I type "plot" I can do drawings one at a time. When I open the project manager and press the publish / plot button, the little flyout window opens and I can select Plot Project. The flyout window closes and the printer icon greys out, but nothing happens. There's no hidden window I can tab to and there's nothing displayed on the command line. I've closed the program and restarted but it still does not work. I just got a new Windows 7 - 64 bit machine and did a fresh install of AcadE 2013 last week Friday. Any help would be great... Thanks
Kyle
Re: Plot Project trouble in 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Kyle
I think I understand your question.
When I used ACE2010 Publisher worked fine from the project. I started on ACE2012 and had problems.
I find thet the publisher in the project area JUST DOES NOT WORK.
I use the publisher using the BIG "A" pull down menue. It works. I have not bothered with the features that are available as it seems to be to a maze of options to muck things up.
This "PUBLISHER" has lost some of the features that were in the Project Publisher that were in ACE2010.
I hope this helps.
John Q
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I suspect you are using dual monitor rite?
I came across another similar topic at this link:
Try and it should be able to solve your issue.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks, lionSG. That took care of my problem.
