• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    JEeten
    Accepted Solution
    Peer tot Peer link possible with Terminals?
    138 Views, 2 Replies
    02-03-2012 01:43 AM
    Hi all,
    It is possible to link components (electric-hydraulic) so if one tag is changed the other linked compnenttag changes also. Does anybody knows a way to do the same with terminals and coils (relay)?
    Using AutoCAD Electrical 2012.
    Do I have to make new blocks with other family code or something like that?
    John van Eeten
    *Pro
    Re: Peer tot Peer link possible with Terminals?
    02-03-2012 10:25 AM in reply to: JEeten
    It sounds like you may be dealing with protection relays, but I'm just guessing.  Managing a peer relationship between relay symbols is possible by using the WDTYPE attribute.  See the help menu for more details.  You will need to add this attribute to symbols that do not already contain it.  WDTYPE was added to support one-line diagram functionality, but other uses are possible.  The attribute value that signifies a one-line symbol is 1-, but you can use custom values, as long as you do not exceed 4 characters for the WDTYPE attribute value.  See the attached screen capture which explains how to manage a peer/duplicate relay coil.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    www.ECADConsultant.com
    Active Member
    JEeten
    02-06-2012 02:44 AM in reply to: dougmcalexander
    Thanks Doug,
    I tried this and this is what I was looking for. Great!
    Best Regards,
    John
