• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    adrien.levasseur
    Accepted Solution
    PLOTDATE / PLOTDATE update
    236 Views, 13 Replies
    01-13-2012 05:11 AM
    I have a TitleBlock "ACADE_TITLE", using WD_TB attribute to uptdate my automatic fields : TIME = PLOTTIME ; DATE = PLOTDATE etc...
    All are working but PLOTDATE / TIME.
    When updating, ACE doesn't care TIME and DATE, even though he cares the other unchanged attributes.
    I also tried *project*.wdt, but i am not sure ACE read it when update.
    See appendix to see my title block.
    Could you help me please ? Thanks
    Distinguished Mentor
    Re: PLOTDATE / PLOTDATE update
    01-13-2012 06:00 AM in reply to: adrien.levasseur
    Did you try using Plot Project and then see if this value changed?
    It appears this is only updated when the Plot Project is run:
    http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2011/Help/User's_Guide/115Project-WideTools/1399...
    At least that is how I read this.
    Hope this helps.
    Bob Hanrahan
    Ace User since 1998
    adrien.levasseur
    01-16-2012 01:22 AM in reply to: testsubject
    When i plot my project ??
    :smileyfrustrated:
    I only tried plotting one draw by one draw....
    Thanks Bob, now this is working
    adrien.levasseur
    01-16-2012 01:26 AM in reply to: testsubject
    To go further :
    Could i use a plotdate with DDMMYY format ? There is no proposition for this format in ACE (wiki)help
    01-16-2012 05:21 AM in reply to: adrien.levasseur
    That I don't know. Maybe Pat or Kevin have the answer to that one.
    Bob Hanrahan
    Ace User since 1998
    btackes
    01-16-2012 01:57 PM in reply to: testsubject
    PLOTDATEMMDDYY
    current date (MM:smileyvery-happy:D:YY format)
    PLOTDATEYYMMDD
    current date (YY:MM:smileyvery-happy:D format)
    PLOTDATEYYYYMMDD
    current date (YYYY:MM:smileyvery-happy:D format)
    This is for 2012 not sure about earlier versions.
    adrien.levasseur
    01-17-2012 02:29 AM in reply to: btackes
    I have same PLOT YMD combinations as you do with my 2009 version.
    Actually, this is not really an important issue.
    I'd rather use YYYYMMDD
    Spoiler
    I just wonder why the format MMDDYY exists, this is non-sense
    Thanks for your help
    Valued Mentor
    rhesusminus
    01-18-2012 06:26 AM in reply to: adrien.levasseur
    I'd just like to add that you can always use a FIELD as an attribute text. Plotdate/time is a field that AutoCAD (Electrical also) updates automatically when a drawing is plotted. No matter hoe one plots the drawing (manually, Plot Project etc.)
    THL
    THL
    adrien.levasseur
    01-19-2012 02:36 AM in reply to: rhesusminus
    You are reaviling an interesting point.
    I remember using LISP expression in some of my title block's fields (have a search "tbnp.lsp" for next and previous sheet on this forum, this was brought by dougmcalexander)...
    In the " _Field" command, i found the many date formats, where highlighted "DateTracé" means "PlottingDate". Then with dd/MM/YYYY format, i find the expression :
    %<\AcVar PlotDate \f "dd/MM/yyyy">%.
    So i will soon try in my WD_TB :
    DATE = %<\AcVar PlotDate \f "dd/MM/yyyy">%
    Valued Mentor
    rhesusminus
    01-19-2012 02:51 AM in reply to: adrien.levasseur
    You don't have to put that in the WD_TB attribute or WDT-file. Just insert the field in the drawing template (dwt-file), and it will be a part of all new drawings.
    THL
    THL
