• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    PLC split TAG
    122 Views, 4 Replies
    09-19-2008 12:53 AM
    How can I position Tag attribute of the parametric PLC split part? Is there a file used for making split parts?
    Please use plain text.
    Active Contributor
    btackes
    Re: PLC split TAG
    04-27-2012 09:00 AM in reply to: vladop
    Did you ever find an answer?  I was wondering the same thing.
    Re: PLC split TAG
    04-27-2012 11:27 PM in reply to: btackes
    No, I still use Move Attribute command to position it.
    *Expert Elite*
    Re: PLC split TAG
    05-02-2012 08:20 AM in reply to: vladop
    Here is a Wiki on how to spilt a tag into two pieces.
    To do this with the Parametric, you will have to go into the appropriate PLC component drawing and add these tags to it but it should be pretty painless. I recommend making copies of hte files before to make any changes.
    http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2012/Help/0266-Symbol_L266/0271-Split_a_271
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    btackes
    Re: PLC split TAG
    05-02-2012 08:29 AM in reply to: vladop
    The issue is not splitting the tag, it's splitting the PLC over multiple pages.  AutoCAD Electrical adds the tag to each section of the PLC and its these tags that we want to be able to position.  Unfortunately I cannot find any documentation on how the tag is added to subsequent sections of the PLC.  It's not part of the PLC database as far as I know.
