• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    PLC componet tag - can It be Family/Sheet#/Vgrid/Hgrid
    131 Views, 7 Replies
    04-03-2007 07:46 AM
    ACADE 2006 I have included a drawing.
    1. How do I set this up so the PLC tag gets displayed like the component tags? I want the PLC tag to be PLC0303F (The sheet number does not get displayed). I only get PLC03F. Our setup is for componets is family/Sheet#/V grid/H grid. Components tags work just fine.
    2. When the module is broken, the tag does not display correctly either.
    Please use plain text.
    *Pat Murnen \(Autodesk\)
    Re: PLC componet tag - can It be Family/Sheet#/Vgrid/Hgrid
    04-03-2007 11:11 AM in reply to: ken.coulter
    Ken, Is this for a parametrically built PLC module? I believe that the Tag
    format for these is actually set up in the PLC Module Builder Database. I've
    included a screen shot where this is defined. You can edit the plc database
    directly if you need to do a lot of edits but you should make a backup copy
    first just in case.
    Pat Murnen
    wrote in message news:5539831@discussion.autodesk.com...
    Active Contributor
    04-03-2007 01:52 PM in reply to: ken.coulter
    Thanks, Pat it worked great.
    The PLC database file editor is handy tool.
    Distinguished Contributor
    CAD-ICE
    04-24-2012 03:23 AM in reply to: ken.coulter
    I know this is an old thread but I have problems following our customer demand for tag format when tagging parametric plc units. The customer wants to tag for instance digital input modules according to following:
     -6D051 where
    6 =%A (Section)
    D =FAMILY
    05= sheet no.
    1  = Line reference
    As can be seen on the attached image I´m not getting the correct result by changing the TAG format in the plc database editor. I have also tried %A%D%S%N but either way I´m not getting the correct result.
    Any comments appreciated.
    Regards, Gary
    *Expert Elite*
    04-24-2012 05:05 AM in reply to: CAD-ICE
    Gary,
    %F is the family variable. Try that instead.
    Bob Hanrahan
    Ace User since 1998
    CAD-ICE
    04-24-2012 07:31 AM in reply to: testsubject
    Hello Bob and thank´s for the hint.
    One thing I´m not clear on is if I use the family attribute, where can I define the default Tag-character for the family in this case PLC. If I use the family attribute, %F the module is tagged with nothing that is, I get correct values in for the section, page no. and line reference but nothing for for %F ??
    Help...
    Regards, Gary
    *Expert Elite*
    04-24-2012 09:33 AM in reply to: CAD-ICE
    I did not want to leave you hanging. My ability to help is pretty limited right now because I do not have access to ACE. Maybe one of the other users here can chime in.
    Bob Hanrahan
    Ace User since 1998
    CAD-ICE
    04-24-2012 01:12 PM in reply to: testsubject
    Thank´s again Bob. Hope somone else is following this thread.
    Regards, Gary
