• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Member
    PLC Parametric Build files
    85 Views, 2 Replies
    12-02-2003 04:15 AM
    In the VIA version I was able to set a variable in the .env to look on the server for the .dat files, I don't see how to do that in the AcadE version.
    -Jacques
    Please use plain text.
    *Autodesk, Inc\
    Re: PLC Parametric Build files
    12-02-2003 05:52 AM in reply to: jbenoit
    Jacques
        To point to a new location for
    the plc.dat files, you need to add a path to the AutoCAD support paths.  I
    do not recall there ever being a path in the env file for this, it has always
    been accomplished through the general AutoCAD support paths.  If you remove
    the files from your local system, add their location as an AutoCAD support path,
    and you should be ready to go.  To verify that the program is finding the
    information in the correct location, when you go to insert your first PLC card,
    look in the upper right hand corner of the main selection dialog.  It will
    give you the location it is finding the main PLC.DAT file.  I hope this
    helps.
    Sincerely,
    Jared Bunch
    Technical Support Specialist
    Autodesk, Inc
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    In
    -Jacques
    Member
    Re:
    12-02-2003 08:29 PM in reply to: jbenoit
    Jared, I am sorry, you are correct.
    By the way, good to see you are still in tech support, we have spoken a few times in the past.
