• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    *krollenhagen
    PLC I/O descriptions
    60 Views, 1 Replies
    11-24-2003 05:08 AM
    Does anyone know if the plc i/o module can pull the description for the
    input / output point from the device that is wired to it?
    Keith Rollenhagen
    Thierica Automation Group
    Please use plain text.
    *Autodesk\
    Re: PLC I/O descriptions
    11-24-2003 10:47 PM in reply to: *krollenhagen
    There's currently not a way to populate the I/O module's descriptions with
    connected component descriptions all at once, but you can do it selectively.
    Hit the EDIT COMPONENT toolbar button and pick on the PLC I/O module. The
    EDIT PLC MODULE dialog appears. Highlight an I/O address in the upper
    left-hand selection list. Then find the "pick - pick device to capture Desc
    text" button in the upper middle of the dialog. Now pick on the connected
    device. Its description text will be captured and applied to the description
    for the currently selected I/O point in the dialog. Repeat the process for
    the other I/O point addresses.
