• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Active Member
    ronbotkin
    PLC I/O Utility
    102 Views, 3 Replies
    02-03-2012 07:16 AM
    I have been trying to use this utility to add multiple drawings to the PLC.  It works fine for the first module and then just stops.  I have tried pause between drawings and free run both with the same results.  Pause betweed drawings says it is supposed to return with a dialog box but I never get one.  Any ideas what I'm missing.  I'm using ACADE 2011.  I used to use this in ACADE 2005 and it worked fine but now there are so many more nice enhancements to it I would really like to get it working.
    Valued Mentor
    rhesusminus
    Re: PLC I/O Utility
    02-03-2012 08:25 AM in reply to: ronbotkin
    Does the demo excel sheet that comes with AcadE work?
    THL
    THL
    Active Member
    ronbotkin
    Re: PLC I/O Utility
    02-03-2012 08:34 AM in reply to: ronbotkin
    Yes it does!  I guess that means I have something wrong in my spreadsheet.  I have found that I can get it to continue if I put in the SKIP or NEW_DWG values after a module but then it has the unwanted side effect of skipping ladders or pages.  I'll have to check compatibility issues in excel to see if there is something there.
    Active Member
    ronbotkin
    Re: PLC I/O Utility
    02-03-2012 08:42 AM in reply to: ronbotkin
    I found the problem, no blank line before the next module.  The smallest things can become major sometimes.
