AutoCAD Electrical
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
PLC I/O SPREADSHEE T MOD
Options
- Highlight
- Email to a Friend
48 Views, 3 Replies
06-18-2004 12:27 PM
I have modified the wdio.dcl file to be able to insert more than the original (6) ladders per drawing. This works fine for module insertions but not for line reference numbers. Only (6) ladders receive the full line reference numbers with the remaining ladders receiving the first line number and the last line number per ladder. Is there a value in the wdio.lsp file that needs to change?
*Nate Holt \(Autodesk\)
Re: PLC I/O SPREADSHEE T MOD
Options
- Highlight
- Email to a Friend
06-20-2004 09:47 PM in reply to:
tomw47
"tomw47" wrote in message
news:14277243.1087586880690.JavaMail.javamailuser@ localhost...
Options
- Highlight
- Email to a Friend
06-20-2004 09:50 PM in reply to:
tomw47
For the 7th through "nth" ladders, is the first line reference number
correct? If so, with the drawing on screen, select the "revise ladder"
command. Advance to the 7th ladder and start toggling the check boxes in the
next to last column to "ON". See if this will regen missing line reference
numbers.
Options
- Highlight
- Email to a Friend
06-21-2004 05:05 AM in reply to:
tomw47
Thanks for the tip. It worked. I also noticed that the ladders are resequenced/numbered from top to bottom/left to right. I had several ladders below others and sequence was not correct. I now know that they all have to be in a straight line left to right in the order I want them. Good to know.
Thanks again
Thanks again
