AutoCAD Electrical
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: One Line Diagram Help!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do I have to insert all the "required" tags? If there are any errors errors found in the symbol, will this cause them not to work?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A quick look shows that you are missing all the info that is needed in the symbol to make it intelligent:
I recommend using Symbol Builder which will provide you with all the attributes that need to be on a symbol to make it intelligent.
You also need to change the way you name symbols.
ACE uses the following format:
1st Char - H or V for horizontal or vertical insertion.
2 and 3 char - the family code for th esymbol; i.e., CR for relays, MO for motors, SS for selector switches. This is how ACE knows which table to look in in the database for part information.
4 char - 1 for the Parent Symbol and 2 for the Child Symbol
5 char - 1 is a NO contact, 2 is a NC Contact. Used mostly with relay children symbols and switches.
6 char and up - these can be whatever you want to make the symbol distinctive.
Here is a wiki that goes into it in more detail
Hope this helps.
Ace User since 1998
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for the quick reply. I did use symbol builder when I created them. I changed name and file save location though, should I keep ace's default naming and save location. It sounds like that would help. I am just trying to create a basic line diagram, my blocks do not need to be intelligent(except for wire connectin points). Should I just attach them as xrefs and connect the wires to a spot on the box, not an actual "terminal". I have a feeling I am making this much more complicated than it needs to be. Thank you again
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok it appears that renaming the block accouding to the way Bob explained has fixed the problem. THANK YOU!!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not a problem. I like to help.
Ace User since 1998
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I thoight it fixed the issue but it didn't. Im getting closer but not 100%. Thanks again tho
