• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Member
    Old Block Attributes
    125 Views, 3 Replies
    11-03-2003 05:52 AM
    Older blocks (from before AE) do not prompt for data when inserted. I'm used to seeing the prompts on the command line. Is there a switch that contols this?
    DanG
    ASM
    Please use plain text.
    *Autodesk, Inc\
    Re: Old Block Attributes
    11-03-2003 06:11 AM in reply to: DanG
    Dan
        That sounds like you are using
    the Vanilla AutoCAD insert.  You want to try and use the INSERT COMPONENT
    and INSERT FOOTPRINT functions from the Electrical package as much as
    possible.  They have additional functionality built in which the VANILLA
    AutoCAD INSERT does not and therefore using it could create more work for
    yourself.  There is a variable for prompting for attribute values,
    ATTREQ  set this to 1.
    Good Luck!
    Sincerely,
    Jared Bunch
    Technical Support Specialist
    Autodesk, Inc
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Older
    DanG
    ASM
    Member
    11-03-2003 10:25 PM in reply to: DanG
    Thanks!
    DanG
    ASM
    Active Member
    04-18-2006 11:07 AM in reply to: DanG
    I am having an issue with ATTREQ resting to 0. I'm working in a project with approx. 30 different drawings. It seems after I switch from drawing to drawing a few times, it resets. Is there a fix for this?
