• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Accepted Solution
    Next sheet question
    380 Views, 10 Replies
    08-09-2012 07:51 AM
    Hello.
    Once Nate holt explained how we could make a lisp that shows the "next and previous" sheet number.
    I don't have it now and I am very lost.
    I don't know if it OK but I only use a *.wdp file complemented with the Sheet set manager options. (Sometimes I need to mix Civil and electrical).
    Maybe I need another config file.
    Can anybody explain it again? maybe have the original explanation copied.
    sorry to bother
    Arq. Ernesto fraga
    Montevideo - Uruguay
    Please use plain text.
    Valued Contributor
    Tee.Dee
    Re: Next sheet question
    08-12-2012 09:56 PM in reply to: ernesto.fraga
    Hi, Ernesto.
    I have attached the .lsp file I use.
    Also in the WD_TB attribute I have the following code:
    LINE42;PREVSHT = (if (setq x (findfile "tbnp.lsp" ))(progn(load x)(c:smileytongue:revsheet)) " ");NEXTSHT = (if (setq x (findfile "tbnp.lsp" ))(progn(load x)(c:nextsheet)) " ")
    Paste the tbn.lsp file wherever the path for your .lsp files are.
    See if that works.
    Tim
    08-13-2012 12:16 PM in reply to: Tee.Dee
    Thanks a lot
    08-13-2012 12:20 PM in reply to: Tee.Dee
    Do I have to use Line 42?
    What is the smile tongue? :smileyhappy:,
    *Expert Elite*
    08-13-2012 12:26 PM in reply to: ernesto.fraga
    colon p    ":"  "p"
    Bob Hanrahan
    Ace User since 1998
    Valued Contributor
    Tee.Dee
    08-13-2012 03:37 PM in reply to: ernesto.fraga
    No I dont think line 42 means anything, sorry, its just where that particular attribute happens to fall.
    *Expert Elite*
    08-13-2012 03:41 PM in reply to: Tee.Dee
    Or someone is making a Doug Adams reference
    I got my towel
    Bob Hanrahan
    Ace User since 1998
    Valued Contributor
    Tee.Dee
    08-13-2012 03:48 PM in reply to: ernesto.fraga
    Bob, I dont get it... what am i missing? :smileywink:
    *Expert Elite*
    08-13-2012 04:05 PM in reply to: Tee.Dee
    Well, you did wink, but for those not in the know
    In Hitchhikers; Guide To The Galaxy, The answer to the Meaning of Life is 42.
    I'll let you read the rest of them to find out the question...
    And all well travelled beings bring their own towel.
    Bob Hanrahan
    Ace User since 1998
    Valued Contributor
    Tee.Dee
    08-13-2012 04:07 PM in reply to: testsubject
    Arrr thanks for that, the wink was only for lack of a confused face...
