• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    New to electrical, only have Allen Bradley parts
    1203 Views, 5 Replies
    04-18-2012 10:30 AM
    Installed Electrical as part of Inventor Suite, but the only Manufacturer parts that are listed are from AB, how do we add additional parts from other manufacturers?
    Thanks,   I am sure I will smack myself in the head once someone tells me cause it is probably simple
    Please use plain text.
    Re: New to electrical, only have Allen Bradley parts
    04-18-2012 10:48 AM in reply to: jtwalker1
    Don't hit yourself too hard  ;-)
    Re-run the installation of the software and when asked for manufacturers', select all the ones that you want.
    Bob Hanrahan
    Ace User since 1998
    Valued Contributor
    04-18-2012 10:54 AM in reply to: testsubject
    It does not give me the option, when inventor installs it installs everything with no real interaction or questions.
    New Member
    04-18-2012 10:57 AM in reply to: jtwalker1
    I'm in the process of doing the below steps right now.  I also didn't get the select manufactueres during installation.  I don't know if downloading versuses using a dvd makes the difference or not.
    http://docs.autodesk.com/ACAD_E/2013/ENU/index.html?url=filesAcadE_WhatsNew/GUID-61E726C5-69C4-417A-...
    During installation, you specified which manufacturer content to install. You can install additional manufacturer content later.
    1. Close all instances of AutoCAD Electrical.
    2. From the Windows Control Panel select Add or Remove Programs.
    3. From the Add or Remove Programs dialog box, select the latest version of AutoCAD Electrical and click the Change/Remove button.
    4. On the AutoCAD Electrical Installation Wizard, click Add or Remove Features.
    5. On the Manufacturer Content Selection page, select all the manufacturers you wish to install. Click Next.
    6. On the Select Symbol Libraries page, click Next.
    7. Click Update.
    04-18-2012 11:17 AM in reply to: brent.duncan
    That is another way to do it.
    Bob Hanrahan
    Ace User since 1998
    Valued Contributor
    04-18-2012 11:18 AM in reply to: brent.duncan
    That took care of it.
    Thank you for your help
    James
