• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Multiple manufacturers part numbers against a single schematic component
    149 Views, 2 Replies
    02-14-2013 01:31 AM
    I am currently entering manufacturers data against components on my drawings and was wondering if it is possible to enter multiple part numbers against a single component as it is supplied as an assembly and multiple part numbers need to be shown aginst a single component on the BOM.
    Thanks in advance.
    Please use plain text.
    Active Contributor
    kghew1
    Re: Multiple manufacturers part numbers against a single schematic component
    02-14-2013 05:38 AM in reply to: STEVENAR
    Have you tried using the supplementary MFG01 - MFG10 / CAT01 - CAT10 / ASSYCODE01 - ASSYCODE10 attributes - if your symbol(s) include them ? Or if they don't, are you able to modify the symbol(s) to include these ?
    Keith H
    johnq
    02-14-2013 01:37 PM in reply to: kghew1
    G'Day
    The method I use is to use the Multiple catalogue in the edit companant box to achieve this need.
    EG  the sprecher+schuh  push buttons can have a variety of added parts   the basic button  contact   lock mech.
    I use the first contact as the parent part number and the othere parts from the multiple cat feature.  ACE will let you have many parts and you will not need to add attributes later for unforseen needs.   this is not to disscredit the concept from the previous forum member.
    This also works well when a CB can have various trip coils, motors or auxillary contacts.
    Another program I used needed tohave a block for each combination of parts.   Not a good idea.
    Hope this give you somethis extral to think about.
    Cheers  john Quigley
