• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Member
    Multiple attribute definition editing
    149 Views, 2 Replies
    01-16-2004 12:29 PM
    Is there a way to change the definition for multiple attributes at one time.
    For Ex: I am trying to change the tag definition for several attributes and up to now I only know of editing one by one.
    the attribute tag definitions are something like :
    TERM40 WANT TO CHANGE TO ----> TERM51
    TERM41-----------------------------------> TERM52
    TERM42-----------------------------------> TERM53
    TERM43------------- ETC.
    TERM44
    Do you have a better way of doing this?
    I have hundreds of these to change
    Jorge Martinez
    Please use plain text.
    *Abhishek Singhal
    Re: Multiple attribute definition editing
    01-16-2004 09:30 PM in reply to: riquemartinez
    I see you have to add 11 on to the TERM no. Are these attributes on a single file ... or do you have several such files ? In any case, I think a small custom VBA/Lisp routine can be made to do the task ... Regards Abhishek "riquemartinez" wrote in message news:7879526.1074285021140.JavaMail.javamailuser@localhost... > Hello, > Is there a way to change the definition for multiple attributes at one time. > > For Ex: I am trying to change the tag definition for several attributes and up to now I only know of editing one by one. > > the attribute tag definitions are something like : > > TERM40 WANT TO CHANGE TO ----> TERM51 > TERM41-----------------------------------> TERM52 > TERM42-----------------------------------> TERM53 > TERM43------------- ETC. > TERM44 > > Do you have a better way of doing this? > I have hundreds of these to change > > Thanks > Jorge Martinez
    Member
    01-19-2004 05:31 AM in reply to: riquemartinez
    Hi Abhishek,
    No. Not necessarily 11. It could be any value.
    These are the values (Attributes) created when using the ACAD Electrical. When you create a panel footprint with terminals it creates these attruibutes.
    In my case the blocks can be rather large with losts of terminals (100+) and it becomes quite lentghy to change attribute definition by hand when copying from another block and so forth.
    All attributes are in the same drawing file, If I understood you correctly.
    I have attached a sample in case you will need.
    Thank you
    Jorge Martinez
