AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Motor wire connection s - X0STRETCH
- Highlight
- Email to a Friend
How should the X0STRETCW work with motor wire connections? If I draw a three wire bus with vertical spacing value as 5 and insert a motor symbol on the wire (mm scale 1) it does not connect wires automatically...It seems that this works only then when the spacing is big enough over 7 (without PE connection) and spacing 10 with PE.
Is the only way to scale the symbols before inserting them?
Mako
Re: Motor wire connection s - X0STRETCH
- Highlight
- Email to a Friend
Hi.
AcadE's X0 type connection point doesn't like narrow wiring.
So, for the Norwegian/Danish localizer for AutoCAD Electrical, I created special 5 mm symbol for all symbols that needes to be narrower, like this:
Then, in the demo project, we added a search path to this library of 5mm symbols in the project:
THL
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
- Highlight
- Email to a Friend
Hello Rhesusminus.
one quick question to your answer. How are you familiar with the Norwegian/Danish localizer ?
Are you working in Scandinavia?
I´m working with ACADE in Iceland and we have similar requirements as in Scandinavia.
Would be interesting to hear from you on this matter.
My work e-mail is sit@verkis.is
Regards, Gary
- Highlight
- Email to a Friend
I have tried this, but I think the reason the smaller spacing does not work well is because of how the X0STRETCH attribute is designed.
The connecting line is extended from the insertion point of the X0STRETCH attribute to the three phase lines. The path or angle of the connection line is determined by the angle created from the insertion point of the symbol (usually the center of the motor) out through the insertion point of the X0STRETCH attribute.
I suspect the lines aren't connecting properly because the distance between the X0STRETCH is too close to the distance between the three phase wires.
Brunette Technologies, LLC
randy.brunette@brutec.us
www.brutec.us
- Highlight
- Email to a Friend
Sorry, I meant to say that I have NOT tested this situation.
So, now I have tested it. The three phase motor symbol I inserted had a spacing of 12.8078 between the two X0STRETCH attributes. This means if the rung spacing was smaller than 6.4, the wires will not connect correctly.
www.brutec.us
