AutoCAD Electrical
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Modifying Blocks/Att ributes to Company Standards - Need Help
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
62 Views, 7 Replies
06-17-2004 08:15 AM
Hi guys, I have a couple of questions.
1. After working with ACad Electric for several projects, the company that I work for has asked me to make a few changes to the component blocks. For starters, they want them to be larger. All of my drawings are D size and are scaled down to 11x17. This is fine, except the components are a tad too small, so is there a setting that I could change to increase their size without manually doing it for every component?
2. The other thing the company has asked me to do is raise the attribute text above the component more than it is currently. Again, is there a setting that I could change that would universally raise the attributes, or would I have to manually edit each one?
*TestSubject_US
Re: Modifying Blocks/Att ributes to Company Standards - Need Help
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-17-2004 09:31 AM in reply to:
teichelberg
If you go to Swap Component, You can swap an old component for a new
Component (Option A) or Update Block (Option B). This is the option you
want. Click on LIBRARY Swap. In the next Dialog box, Change the insertion
scale to the amount you want the blocks to "grow". Select Project wide and
all blocks in the entire project will be increased by that amount as long as
they are in the path listed in this dialog box. If you have some special
blocks that you have created and they are not in this path, you will have to
rerun this for the different paths. This will increase (or decrease) the
size of the symbol and text so this may solve both of your questions.
That's it!
Robert Hanrahan
Weigh Right Automatic Scale Co.
ACE user since 1997
"teichelberg" wrote in message
news:3424901.1087485350496.JavaMail.javamailuser@l ocalhost...
*John Pullen
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-18-2004 08:03 AM in reply to:
teichelberg
Seems like there used to be a script to run to resize all the blocks...
Maybe someone else remembers that?
"TestSubject_US" wrote in message
news:40d1c739$1_3@newsprd01...
as
to
> That's it!
> Robert Hanrahan
> ACE user since 1997
that
For
too
or
*Nate Holt \(Autodesk\)
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-18-2004 10:23 AM in reply to:
teichelberg
Yes, there is a tool that can blast through an entire symbol library folder
and scale symbols up or down and/or adjust attribute sizes. Go to the
"Components" pulldown menu > "Symbol Library" > "Modify Symbol Library".
"John Pullen" wrote in message
news:40d3045f$1_1@newsprd01...
insertion
and
long
> as
have
> to
> > That's it!
> > Robert Hanrahan
> > ACE user since 1997
> that
> For
and
> too
attribute
> or
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-21-2004 01:49 PM in reply to:
teichelberg
Thanks guys. Using your tips, I am able to easily resize component blocks and was able to change the text style to Arial.
One more question...
Is it possible to do a general move of some of the attributes on the PLC blocks? I want the tag to be on top with the rest of the info, and not resting inside, and I want to hide the number attributes and move the terminal descriptions above the terminal screws. However, I have a feeling that I will have to do all of that manually. Anyway, thanks for all your help!
*John Pullen
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-21-2004 02:55 PM in reply to:
teichelberg
I'm not aware of a built-in command for doing this one. You could always
write a script to do that.
news:13127033.1087850975355.JavaMail.javamailuser@ localhost...
help!
*TestSubject_US
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-22-2004 08:08 AM in reply to:
teichelberg
It is not difficult to do, just a little time consuming. From here, you will
have to modify the original blocks that you inserted and then just do an
update again. When asked, select the updated blocks instead of the old ones.
I have modifed several blocks and when I need to, I copy them to a new
directory that I created for user modified blocks and add it to the
filepath.
Robert Hanrahan
ACE user since 1997
help!
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-07-2004 03:18 PM in reply to:
teichelberg
Can this modify the height of the CAT and MFG attributes? Is there a way to quickly change all of the symbols in the library so that these attributes are visible by default?
Jay
Jay
