• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    Missing some manufacturers
    442 Views, 6 Replies
    02-11-2008 07:04 AM
    On install, I thought I selected all the manufacturers from the list of those that I wanted to include in my library, but apparently I didn't. How do I install these into my program, aside from reinstalling the software?
    Please use plain text.
    *Pat Murnen
    Re: Missing some manufacturers
    02-11-2008 07:20 AM in reply to: MrGray827
    Close AutoCAD Electrical first.
    1.. From the Windows Control Panel select Add or Remove Programs.
    2.. From the Add or Remove Programs dialog box, select the latest version
    of AutoCAD Electrical and click the Change/Remove button.
    3.. On the AutoCAD Electrical Installation Wizard, click Add or Remove
    Features.
    4.. On the Add/Remove Features page, click Next.
    5.. On the Manufacturer Content Selection page, select all the
    manufacturers you wish to install.
    6.. On the Select Symbol Libraries page, click Next.
    7.. Click Next to continue.
    Hope this helps,
    Pat Murnen
    wrote in message news:5844275@discussion.autodesk.com...
    Active Contributor
    vu.do.mylangroup
    02-10-2011 12:06 AM in reply to: *Pat Murnen
    how to install more manufacturer conten than autodesk autocad electrical 2011 provided?
    Distinguished Contributor
    02-10-2011 03:15 AM in reply to: MrGray827
    You can easily  add new manufacturer and catalog  items to database in AutoCAD Electrical. If there are more (hundreds of..) products I recommend to use MSAccess or other software which can read *mdb format. You can convert the tables to Excel format and fill the information and convert back to MSAccess.
    Mako
    Active Contributor
    vu.do.mylangroup
    02-13-2011 05:02 PM in reply to: mako68
    Hi mako, how can i find new manufacturer and catalog  items?
    Thanks for your help
    Distinguished Mentor
    02-14-2011 03:05 PM in reply to: vu.do.mylangroup
    Add the new components as you use them in your drawing (assuming you know the required cat/man information).
    Other than that, you can always ask your supliers for a database in excel format and import that into the catalogue file using MS Access
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    Active Contributor
    vu.do.mylangroup
    02-15-2011 10:54 PM in reply to: Icemanau
    Thank you very much
