• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    Re: Mapping catalog information for cables into visible attributes on dwg´s
    02-02-2012 10:28 AM in reply to: testsubject
    There is a new command in ACE 2012:
    Ribbon:  Project tab -> Other Tools panel -> Component Update From Catalog
    OR
    Command entry: AEUPDFROMCAT.
    If you have older version try lisp in attachment.
    You can find this lisp in Electrical Help -> API Help -> Samples Index -> wd_get_pinlist
    02-03-2012 03:47 AM in reply to: vladop
    Hello Vladop and many thanks for your reply.
    I´m working with ACADE2012 so I could use the component update from catalog. Seems though that some items are missed by this tool for some reason....but 90% of items are updated. The ones that are missed I simply edit the relevant component and reload the component data with the look upp and the component is updated!
    I have no explanation for this behaviour but as mentioned above, only few components are missed.
    Thanks again for your valuable input.
    Regards, Gary
    02-03-2012 05:05 AM in reply to: CAD-ICE
    To update drawings you can use Export/Import spreadsheet data.
    On this page
    http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2012/Help/0818-Reports818/0826-Export_I826
    under
    Update drawings from spreadsheet data -> Show me - Drawing Settings example
    there is a video that explains how to use it.
    Vlado
