AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Mapping catalog informatio n for cables into visible attributes on dwg´s
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi there,
I´m trying to find out how to map catalog information for cables into attributes on dwg´s in my project. I have attached an image that shows what I´m trying to establish. Any hints are deeply appreciated.
Regards, Gary
Re: Mapping catalog informatio n for cables into visible attributes on dwg´s
- Highlight
- Email to a Friend
What I would do is use the TEXTVALUE field (under the USERx fields), and would want the RATING1 attribute to be filled with the info you want. To do this, type excatly this in the TEXTVALUE field to achive your specific example result: RATING=4X4 MM² CU
Electrical Design Engineer
UNIQUE HYDRA (PTY) LTD
A Unique Maritime Group Company
- Highlight
- Email to a Friend
for more info see help topic on "TEXTVALUES" - rating and miscellaneous attribute value assignment
- Highlight
- Email to a Friend
Dear Evan,
I tried that already i.e.. Added a RATING1 attribute to the symbol and inserted as you proposed the following text into the textvalue field "RATING=4X4.0 MM² CU" Instead of inserting the textvalue as expected, the software looks up the catalog conductor list and inserts that into the "Wire/Color Id" field in the insert / edit cable marker (parent wire) dialog box (see attached image) ?? Any comments ??
Regards, Gary
- Highlight
- Email to a Friend
In the database, each record has a TEXTVALUE field. This is where you would place the RATING1=4X4.0 MM² CU value. Then, when you select that catalog number, the Rating value will automatically be filled in in the Insert/Edit Component dialog box.
Hope that clears it up...
Ace User since 1998
- Highlight
- Email to a Friend
Dear Bob,
did you read my last post and look at the attached image. Seems like the textvalue field has different behaviour when there are cable markers involved? As can be seen on the image, the insert/edit dialog box does not show up with the Rating field but the Wire Color/ID field which I think is in some way connected to the conductor list for this cable.
Thanks for your comments and help.
Regards, Gary
- Highlight
- Email to a Friend
As you noticed RATING1 is used for Wire Color/ID.
Add RATING2 attribute to cable marker block and use RATING2=4X4.0 MM² CU in TEXTVALUE.
- Highlight
- Email to a Friend
Beat me by 7 minutes. I wanted to test it first... hehe
Ace User since 1998
- Highlight
- Email to a Friend
Hi Bob,
just one other issue...in order to complete this task I need to reload the data from the component database. Is there a project wide utility to refresh data assigned to components such that the new data are retracted from the default_cat_mdb database?
Thank´s again, Gary
- Highlight
- Email to a Friend
I am not sure about that one. Just filling in the value using a script will not (afaik) initiate an update from the database. Sorry I could be of more help.
Ace User since 1998
