• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Managing ACE2005
    29 Views, 1 Replies
    03-25-2005 01:27 PM
    Hi All,
    I am a relatively "new" user with ACE2005. I have been using it for about 10 months now (all on my own) and have a fairly ok knowledge on running what I need.
    My question is, our company finally hired another designer and now I want to put the default catalogs and library that I have developed over the last year on the network so that both myself and the new guy can have access to it. I have the library on the server, but not real sure how to set up ACE defaults to look there opposed to looking in C:doc and settings...
    Mike
    Please use plain text.
    Distinguished Contributor
    Re: Managing ACE2005
    03-25-2005 08:07 PM in reply to: MReed
    MReed,
    That is a great question that I see, and hear quite often in my profession. There are several levels you can put on a network drive. You can place symbols, catalogs, support files and some other things on there. The main place you will have to make changes to your system (to point ACE to the new locations) is the WD.ENV file located in your C:\doc......\aedata directory. this file can be opened with any text editor program. Basically you will find the entry that maps to the local space and change it to the network path.
    I hope this helps
    Robert Stein
    INCAT
    rstein@incat.com
    www.incat.com
